60mm Fan
richardd
Geraldton
Hi I these 60mm fans
I was wondering how I connect them directly to a power supply. Not sure what the yellow wire is for...
Derf
am now a 5v hypocrite
Narellan Vale, NSW
Usually its this:
Which contradicts the standard PC power supply wiring (Yellow normally being +12v) So just be careful. If you don't hookup the sensor it tends just to run at 100%
You could also remove the sticker which normally reveals what colour wire goes where.
Grandpa Elf
As Derf said, clip the yellow wire off and use red as V+ and black as V-.
I sell a nice 60mm ball bearing fan if anyone is wanting them.
