AAH said:Just to clarify so bad things don't happen. When Eddy is talking about a hot air gun he's talking about something like http://www.ebay.com.au/itm/2in1-Hot-Air-Gun-Digital-Solder-Rework-Station-SMD-OZ-/350409771145?pt=AU_B_I_Electrical_Test_Equipment&hash=item51960cc889 not a heatshrink or paint removal hot air gun. I used to hand solder every smd component that I used and I use lots but now I use paste and a hot air gun almost exclusively. I use an 18 gauge needle to dispense with and i've shortened it down to only about 5mm as the paste can be a bit hard to squeeze through. Ideally a thinner needle or a proper dispensing needle would do a better job at applying a fine bead but with persistence and care the needle will do. I found the size of the dispensing needle that comes with the strobe and I assume the 5050 kits to be too large and the bead that you lay down gives you too much solder.
http://www.aliexpress.com/product-fm/534188178-TT-tapered-needle-Smoothflow-Tapered-Tips-wholesalers.html
Skunberg said:Eddy do you use your hot air without a tip? 3/4 inch end size about. Or a tip of what size? (approx).
Brian
