BundyRoy
- Apr 9, 2014
I normally use 3 pigtails. Solder the joins, then heatshrink each cable individually, then heatshrink over the lot. I'm concerned about the seals as the heatshrink doesn't slide over the two cables very well in the 3 cable join and then I use silastic to get seal on the two pigtails but always worry about that leaking over time. Any better ways. Thanks.
