jerimiah83b
- Dec 19, 2017
Hey everyone,
Any recommendations on a Butane Soldering Iron for display build? Not looking to spend a fortune, that's means less money for the lights and props. Looking at possibly a Weller Junior or Dremel Versatip unit at the moment.
www.totaltools.com.au
www.dremel.com.au
WELLER Gas Cordless Junior Pyropen Temp Controlled Soldering Iron WSTA6
One hand operation Self-ignition finger switch - no spark lighter required Off button for fast, easy turn off Temperature control gives you adjustment equivalent to15 to 60 watts Knurl release allows you to switch from soldering to hot air in seconds Safety cap ensures unit can't be accidentally...
Dremel - Shape your way | Dremel
All the tools, accessories, attachments, inspiration and motivation you need for making your detailed DIY projects perfect.
