AJ240
Up and running for 2019. Kick off Sun 1st 8pm
Thought I would show you what just came off my printer.
Suitable only for the Falcon 16v3 controller.
I just put this on to thingiverse if you want a copy. Feedback welcome. I can make adjustments if required.would you be able to share the stl? cheers![]()
I think I know what went wrong. I uploaded the wrong version of these buttons. I bet you have the ones without the solid base.Hi I had a friend print one and it works well. Just wondering about the button extender/pusher he printed 7 to go in each hole but they don't work on the buttons or should it only be 1and use it to poke from the outside?
Dave
That's correct i have the ones with a hole. I will fill the holes thanks for a great case.I think I know what went wrong. I uploaded the wrong version of these buttons. I bet you have the ones without the solid base.
Have a look and see if there is a hole in the base ? If so then fill it and it should work fine. My plan was to glue these to the buttons on the Falcon.
Let me know how you go.
