Lowbridge
Is there a controller that’s compatible whith xLights besides the Falcons?
I think I would suggest a RPi (Raspberry Pi) and Pi-Hat. A RPi can be obtained from numerous US retailers in the $40 range for the SBC (Small Board Computer) itself and the Pi-Hat from Falcon for $35 (last time I checked). For software on the RPi, FP (Falcon Player) which is a free download, relatively easy to understand, and works with/along side xLights. FP and a Pi-Hat will work with version 3 RPis and they are a bit cheaper than the RPi version 4s.Just starting and I really don’t want to dive in the deep in yet
Please forgive my lack of knowledge, basically I wanna do the front of my house maybe around 150 lineal feet. So I was just trying to figure out where to start I’ve watched a lot of videos and read up a lot on LEDs specifically dumb versus smart and then the controllers falcon and I think the other one is klup Not sure. also did some homework on power supplies meanwell seems to be the top-of-the-line ones or the go to ones.as far as going in to deep i’m not looking to do 3000 pixels right out the gate so I don’t need all of the large equipment that probably comes with all of that that’s what I meant by going into deep in the beginning or out the gate. I am a beginner so I didn’t want to make things too complicated starting out. I’ve seen the ready-made ones 400 bucks out the door I guess I could go that route but I thought I would just put one together myself therefore I would need to ask questions. So to recap i’d like to do about 150 lineal feet of my house a couple of windows and a door all included no yard props. in 12v . Just the house. And I was only wondering where to get the equipment necessary to complete my little show and if anyone had any suggestions or sites.I want to take a step back for a moment, before this turns into "how about this".
Do we know where @Lowbridge defines "I really don’t want to dive in the deep in yet" ?
Is it complexity or the cost of the controller?
Kulp board VS Falcon doesn't matter much since they're close in price and complexity.
If the thread starter is meaning a beginning point, is FPP stand a good start with a string of pixels or is it over the top? - A big controller gets them started for a large show, but do they want it right now?
Second question is the controller's state. DIY or Ready made?
Obviously ready-made comes with convince but also cost.
I would like @Lowbridge to give us an idea of what they want and price point.
Please tell us what your plans are. We don't know if you're just wanting lights on an indoor tree or the house decorated outside.
Thank you for the adviceI think I would suggest a RPi (Raspberry Pi) and Pi-Hat. A RPi can be obtained from numerous US retailers in the $40 range for the SBC (Small Board Computer) itself and the Pi-Hat from Falcon for $35 (last time I checked). For software on the RPi, FP (Falcon Player) which is a free download, relatively easy to understand, and works with/along side xLights. FP and a Pi-Hat will work with version 3 RPis and they are a bit cheaper than the RPi version 4s.
I suggest avoiding the RPi starter packs as any pieces/parts aside of the RPi (and flash card perhaps) likely will not be able to be used.
There are of course as mentioned, alternatives. I would also suggest using a pixel driver (cape/hat/whaterver) rather than attempting to power a pixel string or strip directly from a SBC. While possible, the 3.3 Volt SBC outputs do not always properly drive the pixels 5 Volt data input. If one is learning, this is a possible problem best avoided.
Oh Yes thank you so much.Another set of controllers that work with xLights is Kulp Lights ( kulplights.com ). The controllers use the BeagleBone or PocketBeagle so the FPP resides on the unit. You should research the differences between this unit and the Falcon. If you like DIY then there are the Renard controllers ( renard-shop.com ), which also work with xLights. Check out doityourselfchristmas.com for more info. There may be others. I could not find information for using MCUs like the esp32 with xLights. WLED is a cool pixel controller that works with the esp32. I have tried to get it to work on my PC but have had networking issues. Perhaps it is the old PC as well as not having a cell phone to run WLED on. But I will keep trying. The esp32 is really cheap from Aliexpress. However, the data line operates at 3.3v so you should get a logic level converter to boost it to 5v. I am waiting on a couple coming from FastTech to see if it will help. I would like to build another infinity mirror using an esp32. The first one uses an Arduino "clone" and they are even cheaper. I found sketches through YouTube videos as well as searches. I'm sure there are others that can fill you in with more information I am not yet aware of.
This is the information that I was looking forI would second the BBB for a startup controller using either Hansons board or if you are just wanting to tinker and haven't got too much cable between the BBB and your lights, just go directly into the outputs for a bit of a play around to get used to how everything runs. Less than $100 and you have a controller that can do more lights than you could find a spot for them on the house. It's just not as plug and play friendly as a lot of the off the shelf boards are.
