BundyRoy
- Apr 9, 2014
I am in the process of setting up my lights. I have a pixlite 16 to control them. I have some strips of INK1003 and some other strips that I had been told were 2811 although it doesn't say on the strip and I hadn't tested them until today.
Anyway I hook up the lights to the pixlite test pattern to see if it works. The pixlite is set to ws2811 protocol (fast). All lights work. So good news about the unknown strip. I can control it.
The hassle is the INK1003 goes red-green-blue-white when it scrolls through the test pattern colours. The assumed 2811 strip goes red-blue-green-white. So the green and the blue are swapped around.
Is there any way I can set up the controller to fix this. I see there is a setting in the controller setup to set the order of RGB but I assume this does all outputs and the problem will persist if I change this.
If I can't do anything then I will just have to remember to send blue when I want green and vice versa in my sequencing.
