Coro Plastic vs. Foam Board
Coro or Foam
  • Total voters
    6
JimmyW
I see that some props are made out of 'coro plastic' and others are made from 'foam board'. If you have had both types, tell me your Personal Preference and Why?
Full disclosure — I make props commercially, so I've worked with both. Honest take:
Coro is my pick for most props. It's about a third the weight of foam board, handles weather well, costs less, and flexes in wind rather than snapping. Big advantages for anything on a roofline or exposed to gusts. The catch: it needs proper surface prep before painting or printing, or the artwork will flake — that's why you see so many coro props with peeling paint.
Foam board wins on finish — dead flat, no flute lines, takes paint beautifully. But it's heavier, dearer, and more brittle.
Short version: coro for large or elevated props, foam board where it's viewed up close and the finish justifies the cost.
Generally agree with CPA.
In the USA it is not easy to get the PVC foam board, all the US vendors are cutting coro, which is much lighter, easier to work with, and performs well overall.
I do have a few PVC stars (imported from Ink Creations and distributed by Your Pixel Store). They're much heavier but they work well and they look great, so I'm glad I bought them.
Overall, you can't lose either way... if you like the prop, you might as well buy it regardless of the material.
Appreciate your honest review, and good to know that you have used both types of material and why.
Have you used both types of props in your display, and how do they hold up in the Queensland weather?
I’m actually very disappointed in the lighting community on this subject. Jimmy had a very good question which he asked and nobody as responded except merryoncherry and myself.
I responded to the poll. Its also not even 24hours since the OP. Allow some time for people to actually see it :)
Keep in mind that traffic to the site wont pick up for another month or two - usually post-mini's is when it jumps up, peaking in November and then going completely dead by the 2nd week in January :-D
i also have both.
So far the PVC foam board from Ink Creations has held up great in Sydney over 2 seasons. The prints look fantastic (I have stars and the set of gingerbread people).
Everything said above is spot on.
Yes, its quite a bit heavier and great for ground based props or smaller items (just my opinion). And you do need to handle it with more care - if you drop it I think there's a reasonable chance it will break - I cracked a small star. On the plus side I was able to glue it back together. Another plus is you can drill it easily if you need to add different mounting holes.
Definitely a case of horses for courses - For me I would continue to use coro for large items or anything that's hanging on the wall or up on the roof where I want it to be light enough to handle up on a ladder and I'd be worried about dropping and snapping it. For ground based I would use either depending on who had a design that I liked.
i also have both.
Cheers. Appreciate you sharing your experience.
I also have both. I have found the corro props become brittle and quite easy to break after a couple of seasons in the Qld Sun. I think the only vendor in Aus that does the foam board is Johnno from Inc Creations, and his quality is really good. Fortunately I have not dropped any of them (yet) so cant speak to the durability of it, but have dropped quite a few corro props. New, no problem. Couple of season old, break / split.
If you look after your props in the off season, and can store them out of the sun, you should easily get multiple seasons out of them irrespective of using corro or PVC foam board.
Appreciate your advice, particularly about the sun and how it degrades the props. I suppose it’s a good opportunity to update the layout and the technology too
^ This.
I have 5mm Boscoyo Chromotrim that I use for roof outlines that is 6 season old and just starting to become brittle. I also have some 10mm props that are similar vintage that are not looking brittle as yet but are also painted. I store all my props under cover out of direct sun and rain during the off season, but are still subject to fluctuating temps.
