Hi all.
This work supersedes any other published numbers for 2811 pixels that is currently pinned.
These results are based on four 100 count strings of Ray Wu square 2811 pixels, 5v, 100mm (4") spacing. Pigtails as supplied by Ray. The power injection however is custom made designed to minimise any voltage drop (insertion loss)
I do have insertion loss figures for the power injection cables by themselves and will post them in and update
Test setup looked like
Doing baseline testing of a 100 count string
The eagled eyed people will note the current meter shows 5.08, both of those meters read a fraction high
Results for 200, 300 and 400 continued below........
| Testing Parameters | |
| Total Pixels | 400 |
| Pixel Type | 2811 Square |
| Pixel Voltage | 5 volts |
| String Length | 100 |
| 150mm Ray Wu pigtails | |
| Power Injection | Custom connector |
| Pixel wire Size | Chinese 18awg - real estimated gauge 23awg - This is the thickest you can buy |
| PI wire size | 0.75mm |
| PI Length | 1m |
| Loop Length - DC | 80 metres |
| Pixel Length | 40 metres |
| Loop Resistance for 100 | 2.16 Ohms |
| Loop Resistance for 400 | 8.00 Ohms |
| Quiescent Current no signal | 250mA |
| Quiescent Current Black data | 290mA |
| Voltage Output from PSU | 5.01 volts |
| Baseline - 100 Pixel String - 100% Brightness | 100.0 | ||||
| Power in start of string only - | |||||
| Colour | Voltage In | Voltage Mid | Voltage End | Current | Average Pixel Current mA |
| Red | 4.89 | 3.48 | 1.49 | 14.9 | |
| Green | 4.9 | 3.81 | 1.31 | 13.1 | |
| Blue | 4.9 | 3.81 | 1.31 | 13.1 | |
| Purple | 4.84 | 3.05 | 2.11 | 21.1 | |
| Cyan | 4.85 | 3.08 | 1.96 | 19.6 | |
| Yellow | 4.84 | 3.05 | 2.12 | 21.2 | |
| White | 4.8 | 2.86 | 2.55 | 25.5 |
