Does HLS Support DMX Open Dongles?
Grandpa Elf
I looked around, even downloaded the software but can't figure this out.
Does the HLS software support output via a "DMX Open" dongle?
angus40
yes it does
steps to take to get it configured
open sequence
add channels and set to a universe # ie )1
create a display group for these channels
now click on the output / select output method and compile for show
you will see your channels and univers assignment click on transport and select usb- dmx .
then you can select your dmx dongle type .
hope this helps
angus40
just to note other than comport and ip settings , all output ptotocols are selected and set after a display group is created
0 channel assignments will show in output config dialog until you have a display group and universe # created for them .
Adam007
Adam007
QLD
Thanks David & Angus.
Angus my original question to David stemmed from this box:
Which is found in the Output > Setup COM ports menu.
I know the COM port number, but was unsure on the rest of the settings. I will just have a tinker this weekend, and see what I can come up with :)
Adam007
Adam007
QLD
I got it going just now before seeing your video anyhow.
Thanks for it tho, hopefully someone will make use.
And yay! I have blinky blinky :)
angus40
Done with the puppies and running with the big dogs then eh !
Congrats :)
