derekbackus
- Jan 23, 2012
After seeing this thread, I went on a search. Found the RGB lights here: holidaycoro.com . They're just $1.29US... seemed cheap to me.
Derek
Derek
mlkren said:I was wondering where you got your 6803 modules.
i am not sure but i think those one are not pixel led ( individual adressable )...it look like dum rgb ..pice is only for 1 module .. but price is so good i wish someone would comment and share their expertize before i buy somederekbackus said:After seeing this thread, I went on a search. Found the RGB lights here: holidaycoro.com . They're just $1.29US... seemed cheap to me.
Derek
These are not pixel based modules you can get the 2801 pixel based module from Ray for $1 a piecebarbotte said:i am not sure but i think those one are not pixel led ( individual adressable )...it look like dum rgb ..pice is only for 1 module .. but price is so good i wish someone would comment and share their expertize before i buy somederekbackus said:After seeing this thread, I went on a search. Found the RGB lights here: holidaycoro.com . They're just $1.29US... seemed cheap to me.
Derek
cheer
smartalec said:Eddy, Eddy, Eddy,
You make things look so easy an good..![]()
I tryed making a candy cane, i learned i cant cut curves in coro for the life of me. ???
I think this one maybe a job for the jigsaw.
I'll keep trying an see if i can turn out something as good as your's
ɟɐsʇǝppʎ said:1: Make a string of 8 modules with the male plug connected to the input side and the female connected to the output side with a lead long enough so that it will then connect to the next candy cane (distance limitations apply, generally max of 3 to 4 metres)
TheQueb said:ɟɐsʇǝppʎ said:1: Make a string of 8 modules with the male plug connected to the input side and the female connected to the output side with a lead long enough so that it will then connect to the next candy cane (distance limitations apply, generally max of 3 to 4 metres)
On the 3 to 4 meters max... Is that between canes or max for the whole set of canes?
