Personally I would power a 5m pixel strip from both ends.
Thanks for the link to this calculator AussieDoug, this will be useful. I haven't put in final numbers for the power supplies yet, I was debating between the generic units or the cheap Meanwell(or maybe not) ones. I'm back on the RayWu generic bandwagon atm, folks seem to have had good results with these, they are significantly cheaper and I plan to have a few spares anyway should any fail.AussieDoug said:Not sure if I over looked it but I only saw 1 of each 5v & 12v PSU's.
With that many lights it will need to be spread across multiple PSU's. To give yourself an idea of loads David-AVD has this great tool on his site.
http://www.da-share.com/calculators/led-strip-string-current/
Interesting; personally I wouldn't (and currently don't) for a 5 metre 12V strip with 30 RGB LEDs per metre. Hopefully there isn't something wrong with this that I need to know about. That's the good thing about getting help from an online community - you get multiple opinions that are all worth consideringDavid_AVD said:Personally I would power a 5m pixel strip from both ends.
I found similar, hence why I usually get 4-6m per PI point as my lengths are 2-2.5m each. But different results for different people, based on cables used etc.David_AVD said:I found that powering 30 l/m 12V 2811 strip from one end resulted in loss of brightness at the non-powered end.
