This is the heatgun I got from Bunnings, a little bit more, but can adjust the temperature if you desired.ooh that's not too bad. I was considering This Station and This Heat Gun (Just because it's reasonably cheap and not a potentially dodgy chinese one haha). And then This 3rd Hand @Pavle
Ooh that's not bad either. Ozito stuff is normally pretty decent for at least entry level stuff. My nail gun is Ozito too.This is the heatgun I got from Bunnings, a little bit more, but can adjust the temperature if you desired.
{productName}
Find {productName} at Bunnings. Visit your local store for the widest range of products.www.bunnings.com.au
Wow thank you @John_82 ! I have never heard of a smart differential reciever... What does it do/how do they work? When would I need one? (So no I haven't ordered one haha oops..)Hi Joshaaye,
I’m new to the hobby also and just today jsunk $750 on 2000 pixels from my tax return too
Questions I have about your setup
I see you are using the falcon controller? have you ordered a smart or differential receiver also? (I didn’t see on your shopping list)
If you are running everything from the one “box” where is that located?
What is the distance between the controller and your start of the pixel runs?
If it is greater than 7.5m you will need to look at null pixels to boost the data signal.
Hansen electronics sell null pixels I believe and falcon sell them too.
I’ve bought the Kulp8-PB as my controller and have 3 x HE123-RX 4 channel differential receivers so that I don’t run everything from a central location and have a distributed layout so my runs from the controllers/receivers are no further than a few meters with my largest run around 6m to the first pixel.
That is mostly correct. You'll also need a differential expansion board in order to use that receiver.
My understanding of this is a Smart Receiver board can connected directly to the F14V4 controller via Ethernet cable and then gives you up to 300 feet to place your next distribution point. The Differential expansion board is optional and would further increase your output capabilities.The 4-String Differential SmartReceiver v2.00 Board can be connected to the F16V4, F48V4 or F16V4 Differential Expansion Boards allowing 4 strings to be placed up to 300+ feet from the controllers.
Can be daisy-chained together with other SmartReceivers v2.0 (maximum six per chain). The chain will share the allocated number of pixels configured for the port it is connected to.
This ^^^^ was also my understanding after watching this video before bed.I don't think that's correct. From the Falcon site:
