You mean series?You could wire the two buttons in parallel and use only one input. The input would not go low unless both buttons are pressed at the same time. If the two buttons also perform other functions when pressed separately, then this won't work.
That I guess depends on how the button is internally made. If it's A Normally Open, closing on press then yes, series is correct.You mean series?
