Help with my first Project
First of all, excuse me my bad english .
My name is Henrique.
I am from Brazil, Maringá Pr and a long time I have been worked with lighting for night clubs and musical Bands.
I make maintenance of equipments and some little projects of LED for this people.
Since last September when I saw a video of Crhistmas Lighting Show in You tube I stayed crazy with I saw.
So I decided get learn how it Christmas Lighting works.
I did downloading of Xlight 4 in my computer and then I started watch your video: XLights 4 Webinar series: Singing faces
I bought two models of controllers on China for start my study here are: E1.31 to DMX Interface 4 universe and WiFi Ws2811/2812 Contoller 7 universe.
I have some doubts and I would like know if is possible help me.
For example:
In my first test I did one unit " Boscoyo-Bulb" with 143 pixel Ws2811.
I put the song and I did the sequence how you show in a video, but I don't know what's happening when I play for test my sequence is having a delay of 4 seconds for start the LED On and when finished the music the sequence have this also delay. In attached
Can you help me with this ?
Also I would like to receive more information about how can I do step by step to put Moving Head with 16 channels dmx or LED Par Cannon with 8 channels in my project.
I would like much of receive your help because you show have very experience in this case Christmas Lighting.
Thank you in advance for your attention.
HENRIQUE BRAZ GARCIA
MARINGÁ PR BRAZIL
keithsw1111
Kellyville, NSW
Hey Henrique. Your English is very good. Much better than my Portuguese.
Do you see this delay when playing it on the screen or only on the lights. How exactly are you playing it to the lights? Using XLights or xschedule?
Have you run check sequence?
Hi Keithsw 1111,
Thank you for your interest in helping me.
As I said before I did the sequence in Xlight using the video as an example and when I play to test only lights have delay the music is correct.
Until now I still not know to use the Xschedule.
I starting with this now, my first test is Boscoyo Bulb and then I want to add two Arcs, two Candy Cane and one Snowflake that I'm doing in this moment.
How can I to run the verification sequence, Please?
Again Thank you for your attention with me.
keithsw1111
Kellyville, NSW
To run check sequence see the tools menu.
There is also an option there to package sequence. If you want you can do that as well and send it to me and I will take a look at it for you.
Hello Keithsw 1111,
[/size]
[font=tahoma, sans-serif][/size]I will go again do the test step by step for try to found a error in my project and then I will send to you for your appreciation and correction case do you may I help me.[/font]
Again thank you for your attention.[/font]
HENRIQUE B GARCIA[/font]
Hello Keithsw1111,
How are you?
A few days ago I sent email asking to help and you replied to me and said for I that want help me.
I was having problem of delay when I did my first test using the Chinese LED Controller, but now already it correct works, I did my own controll with one universe and works very well.
I would like know if is possible to use the Matrix with 10 x 10 pixel connected in " Snake Lines Botton-Left mode" on the Xlight4 ?
In affirmative case, can you show me how can I to do or to indicated a video where I can see this ?
Today I did test of my Boscoyo Bulb and I liked very much that I saw.
Tomorrow I will go test my little Arc and my mini helicoid tree e then test my Matrix 10 x10.
Now I will go to do more boards of controll and put all together for I see how goes stay.
ASAP I would like to show you my little project and ask to you for help me to correct them. Okay
Thank you for your attention.
HENRIQUE B GARCIA.
Maringá Pr Brazil
keithsw1111
Kellyville, NSW
Yes you can snake the pixels. Set the string count to 1 and the strands per string to 10. The. Set the starting location based on where on your prop the string starts.
Hi
Thank you for your quickly answer.
I did of configuration how you said, but when I put the effect for I see it divide the image in two parts.
My little matrix is configured how here:
100 99 98 97 96 95 94 93 92 91
81 82 83 84 85 86 87 88 89 90
80 79 78 77 76 75 74 73 72 71
61 62 63 64 65 66 67 68 69 70
60 59 58 57 56 55 54 53 52 51
41 42 43 44 45 46 47 48 49 50
40 39 38 37 36 35 34 33 32 31
21 22 23 24 25 26 27 28 29 30
20 19 18 17 16 15 14 13 12 11
input 01 02 03 04 05 06 07 08 09 10
Again Thank you for your attention.
MikeKrebs
Is the preview okay?
If yes, then it is most likely controller configuration.
If no, go over the model config again and check that you set the parameters correctly.
Hello Keithsw1111,
How are you Today ?
Long time we don't have contact, I was doing my test with my control and my elements and now I am needing again your help.
I did some units of strings for I do a tree with 500 pixel ws2811.
How my control only have a universe, I did 4 board with 1 universe each for use with this tree.
I separated the board each one with your IP adress and now I put the effect for test, but the image is not normal.
My doubt now is: How can I to do the separation of pixel in each universe for can I see the image perfect.
I have to put the pixel in the universe 01 with 150 pixel adress 01 to 450 and start the other pixel in universe 02 and put more for do the sequence ?
Or how can I to do this, can you help me ?
Please help me
Thank you again.
HENRIQUE B GARCIA
MARINGA PR BRAZIL
