How does voltage drop affect the data line?
Discussion in '101 Display Basics' started by aplant92, Nov 5, 2018.
  1. aplant92
    aplant92 Full Time Elf
    Nov 24, 2016
    127
    10
    Melbourne
    As per the title, I always see voltage drop being talked about around the power going to the pixels, but no real mention of the data line.
    I'm assuming eventually the length of cable leading to pixels will become an issue with the data line, but at what point is this? And is there any way to inject power into the data line to be able to run a larger distance from the controller?
  2. darylc
    darylc 404 darylc not found Global Moderator Generous Elf
    Dec 8, 2012
    552
    154
    It's not as simple as injecting power into the data line - you would corrupt the data. You'd need a null pixel to repeat the data or any of the various products the vendors sell to repeat or amplify the data. Remember the other leg of the data is the ground wire, so make sure you aren't getting much voltage drop along the ground wire. This is why people recommend using 2 wires in a 4 core cable (for example) for ground when using 3 wire pixels.
  3. OP
    OP
    aplant92
    Nov 24, 2016
    127
    10
    Melbourne
    Ok great that makes sense - is there a general recommendation for how far away the first pixel can be from a controller in terms of ensuring the data is fed through properly?
  4. darylc
    Dec 8, 2012
    552
    154
    too many variables (controller model, size of cables, power draw through those cables, interference, etc etc etc) to give general rules of thumb for distance to first pixel.
  5. AAH
    3,117
    284
    It actually depends on the controller as well as the cable. Most controllers should do 10m+ these days. J1Sys controllers which are virtually obsolete now were more like 3-5m. Pixel to pixel distance is typically maxed out around the 5m mark. There's a video on the bottom of http://www.hansonelectronics.com.au/product/null/ that shows the difference between what you can get with pixel to pixel distance with and without a buffer. The same applies when/if you have distance issues from a controller. Unlike the need for power injection like occurs with pixels with data it's actually the rounding of the signal due to cable capacitance that is the limiting factor. The further the data has to travel the less like the original square wave it started as it looks like. The voltage does go down but it's not due to lack of voltage. The pixel cable is both resistive (which is why you need power injection) and capacitive. The effect of the 2 changes the shape and voltage. See the attached pic. The data signal starts off like a) and progressively gets more like c) but unlike in the picture the voltage reduces.
    aplant92 likes this.
  6. OP
    OP
    aplant92
    Nov 24, 2016
    127
    10
    Melbourne
    That's a great explanation - thanks, and the video is also great for illustrating the effects! It's good to know things like that buffer exist too - I take it they just allow you to run longer distances between the controller and first pixel/pixel to pixel?
  7. AAH
    3,117
    284
    They allow the distance between any 2 pixel "things" to be extended. If you need to go further than what 1 will go you can add a 2nd, 3rd, 4th. I had someone tell me that they went to 170m the other day before they ran out of cables on hand. I thought 33m that I got was a good effort. Not sure how many nulls were added to get 170m but it's a BIG number for non differential pixel transmission.
  8. OP
    OP
    aplant92
    Nov 24, 2016
    127
    10
    Melbourne
    Ok cool!
    Out of curiosity - how do the null pixels allow the distance to be boosted so drastically? Are they amplifying the data signal or something similar?
  9. David_AVD
    Jun 12, 2010
    3,941
    261
    The null pixels / signal buffers accept the slightly degraded signal in and regenerate a fresh clean signal out. So as long as they are put inline before the signal gets too badly affected they will work well.
    tooms likes this.
  10. AAH
    3,117
    284
    A standard pixel inserted into the line will regenerate the signal and go an extra x metres. The difference between a pixel and a buffer is the ability to drive a square wave signal into a capacitive cable. Referring back the that square wave picture what you are seeing is the effect of an RC (resistor capacitor) curve. The capacitance is from the length of cable and increases the longer the cable is. The resistance comes from 2 sources. It comes from the very low resistance of the cable (it has to be low to allow amps of current to power pixels) and the internal resistance of the IC that is driving the cable. Pixel chips have a fairly high source resistance / low drive current which is 1 of the major limiting factors in how far they can be separated. The chips that I chose for the buffer were specifically chosen because they have a high drive current. This means that the shape of the square wave data signal remains squarer for longer. Other sneaky stuff in the design is there to reduce the ringing as seen as in d) and e) of the picture.
  11. Kredal
    Kredal New Elf
    Nov 27, 2018
    1
    0
    If I have a 15 meter cable run to a set of strips with 30/10 LEDs with WS2811 chips, can I use a 2811 bullet as the null pixel halfway down the line? Or does it have to be exactly the same type of pixels to regenerate the signal? (Of course, I haven't actually tested this run yet, and it *might* be fine. I'll find out this afternoon, hopefully!)
  12. keithsw1111
    keithsw1111 Full Time Elf
    Oct 11, 2012
    459
    81
    Kellyville, NSW
    You can as long as it is the same voltage
