My point was to test a string of 12v in the exact way you're using the 24v, but inject with 12v rather than 24v. If you have continuity on the data line you might have a problem there
I think I've just miscounted looking at the strip now, no cuts at this stage; it's still on the reel. Looking at the actual strip I can see that they have one chip every 6 pixels so I think I've been duped by Ali.The 24V seed pixels I've played with have the power for each six LEDs in series, but the data still goes through each individual pixel, so whilst you must cut them after every 6th LED, you still get individual LED control. Not sure if your strip is configured the same way.
In your initial post you mentioned 5 LEDs partially lighting which made me think perhaps you're dealing with a cut in the wrong place, but in the post above you mentioned 6 light up at 12V, so perhaps not.
For WS2814: 24v is one chip per 6 leds on strip. 12v is a chip every 3 leds. What you have is normal.I think I've just miscounted looking at the strip now, no cuts at this stage; it's still on the reel. Looking at the actual strip I can see that they have one chip every 6 pixels so I think I've been duped by Ali.
Does anyone have a strip they can recommend and used before with the Falcon that would be good for a big tree? These were 60 pixels/m.
Ok, so I've learnt something today! I thought everything controlled by WS2812 and higher was individual. So do I need to stick with WS2812 or are there others I can go for?For WS2814: 24v is one chip per 6 leds on strip. 12v is a chip every 3 leds. What you have is normal.
Thats a mini treeI suppose "big" is relative haha. 2.5m strips on each string x 10 to make up a flat half tree. Not sure what you'd call that, so I went with big tree.
WS2812 is a WS2811 chip and LED in a single package. 5V only.Ok, so I've learnt something today! I thought everything controlled by WS2812 and higher was individual. So do I need to stick with WS2812 or are there others I can go for?
