Ktag
Hi all
Great site. I am planning my first purchases. I have done a lot of research reading and watching but have to start doing to make it all fit.
If I could get some feedback about my understanding, my plans and my product choices that would be awesome... thanks in advance. Also thanks "Driver" for allowing me to have a stickybeak at your setup the other night.
I plan to purchase the following to start playing around with sequencing, pixels, rgb, controllers etc. Basically to get a hands on understanding.
Ray Wu:
1x 27ch ray Wu controller (or should I get David's DC24 instead...and why)
5m LED 12V WS2811 strip 30
5m LED 5V WS2811 strip 30 (is 30/m enough or should I look at 60/m?)
350W 12V power supply
350W 5V power supply
J1Sys:
ECG-P12R
ECG-D4
EXG-PPX
Power supply for BigW lights - not yet decided.... one option is to use similar to above but 27V/350W (Ray WU $24) or a variable digital power supply (EBAY $100) which could then be used for testing???
My current plans are:
- Use my current Big W multicoloured light strings and cut and build them into mini trees. Connect via 27Ch. Powered by "?? yet".
- Connect the 12 & 5v PS to the P12R board and run the 2 different types of 2811 lights - deciding on whether I will like each pixel controlled (5V) or if each set of 3 is enough (12V).
- Using a 2nd LAN card from one of my computers (separate from home network) E131 to the ECG-D4, then to each of the controllers (using EXG-PPX and switch if required for distance).
- LSP
Now, do I have my head around this yet?? Will the above give me the ability to see what is possible, practise putting it together and then start planning for real?
Probably something else I will need is a soldering iron (my old one is probably 10+ yrs old, never been looked after and I probably couldn't find it anyway).... any suggestions?
Thanks all in advance
Glenn
Ray Wu:
J1Sys:
ECG-P12R
ECG-D4
EXG-PPX
- LSP
Glenn
