Beacy
Great stuff Eddy - DMX is slowly getting pushed off the page
lithgowlights said:Great job Eddy. One question, what program did you use to create the diagram?
kel said:Eddy, is it possible to do an A3 version? I'd like it as a poster for my wall
Great job, btw
Boof63 said:Hi , Apologies if this comes across as a "DOH" question. Can i run ECG-D2 and ECG-P2 from the same network distribution switch. (looing at the ws2811 pixels now instead of 6803)
cheers Boof63
Probably worthwhile pointing out that each of the devices will need a unique IP address.ɟɐsʇǝppʎ said:Boof63 said:Hi , Apologies if this comes across as a "DOH" question. Can i run ECG-D2 and ECG-P2 from the same network distribution switch. (looing at the ws2811 pixels now instead of 6803)
cheers Boof63
An ECG-P2 and ECG-D2 are E1.31 devices so you will need a network switch to connect up multiple E1.31 devices. So as far as the diagram is concerned, it doesnt matter if its an ECG-P12R, E681, ECG-P2 or any other E1.31 controller, they all connect up the same way
