SpeedWalker
- Nov 6, 2011
- Thread starter
- #1
Hi, I am stuck here in NZ and have encounted a problem with my incandecent light strings (Ring Grip and Arlec) which I've had for a few Years. They start off Very bright and as you move along the string the lights get dimmer and dimmer to the point that they are hardly going towards the end.
I have randomly tested end bulbs at the start of the string and they work well and share the same level of brightness as the ones I've replaced at the start to test they bright bulbs from the start of the string are very dim when I replace them at the end of the string.
Also I have used compatable transformers with no success.
Can anyone help as this is not just one set but affects 12 of my sets so they make up a significant proportion of my light display.
Daniel
Daniel
