tom82 said:I tried strapping and found that it frays after a while (especially once the wind moves it around). Also, cable ties tend to accelerate the frays on the ends and I found that I couldn't adequately secure the lights tight enough. I reverted to using PVC coated steel cable which works really well.
The issue with strapping and using strips is that there is a lot of surface area that can catch the wind compared to using strings. The issue is stopping them flapping around and moving in the wind and that's not easy to do with strapping, I used 25mm electrical conduit braced in 4 places and still in the strong wind you could see the strip move a little but it was overall a much better alternative to using strapping which I had originally planned to use.
