warsome
Wires? who needs wires!
- Thread starter
- #16
ChrisB said:It turns out my distance to first pixel was way to long. I ended up using pixel extenders which I'm not to fond of either. Please post up how this worked for you. Thanks Chris
HI,
I worked out I would have this problem during my dry tests in the garage, So I ended up talking to ED and got my hands of the very first P12D http://auschristmaslighting.com/forums/index.php/topic,4965.0.html I may have been the only if not one of the very few to use it in a show this year.
Ran a dream... not a problem after I got over the initial cable connection problems I had with the connectors.
I ended up running many of my lights within 3M of the box (my 12 string tree) and the other lights I had cable runs of upto 30M of Cat5e ... I did not need to Power Inject at all, just had the P12D then 30M of Ethernet then into a PPR-A, from there one of my standard 2.5M patch leads into the light strings. I only had one string per run so I could avoid having to inject power.
Next year in my new house my controller boxes will be mounted next to my power meter, and I have (while the house was being built) pre-run 30 cat6 runs around the front of the house to where I pre-planned to put parts of my display, I have also placed underground conduit to different points in my front yard with pull though cables so I can have stuff there
