Need to stop flashing controls on 2 string led
breakingbad
How do I stop these from flashing. Nothing like them explained on here. Can I directly connect the transformer output to the led strings?
Thanks in advance.
That controller would appear to be from one of the new style 2-wire LED strings. Each of the two sets of colours requires a different polarity.
There's no simple way to have all the LEDs light up steady. If you bypassed some of the circuitry you could have either set on, but not both.
About the only other option is to run them from an AC transformer, but getting the voltage correct may be tricky. A small 24V AC transformer may work.
I've had a bad day so far so I need some comic relief. If you unplug them they will stop flashing ;)
