New Pixel Matrix
Trikky72
Now that I have gotten my head around the software side of controlling pixels with Xlights/Falcon Player etc. and most importantly have the ok from the minister of finance since she liked the way the mega tree and small matrix(30x30 pixels) looked.
I thought it would be best to get some input from all the knowledge on here before I go ordering any LED's from Ray Wu, the area that I want to cover with the matrix is 5500mm wide x 1600mm high and facing west so gets the full summer sun in the afternoons.
The options that I have thought of so far are:
1/ pixel strips 5m wide x 20 rows attached to a frame made using 20mm PVC pipe using cable ties
using these pixel strips https://www.aliexpress.com/store/pr...ml?spm=2114.12010612.8148356.8.b4ec2c9cOk9nDO
2/ 100 nodes spread over 5m x 20 rows attached to a frame using 25mm PVC pipe with holes drilled for each node
using these https://www.aliexpress.com/item/18A...pm=a2g0s.13010208.99999999.274.72a13c001yLknO
both of these options would have the PVC pipe strung on vertical runs of 3 stainless steel wire in a similar fashion to this
View: https://www.youtube.com/watch?v=cL9Dy0RlEEw
3/ This option would be either 12mm pixel strips or 12mm Mega Tree strips from BOSCOYO, I would need some sort of frame on the top and bottom to run these vertically, mounting these top and bottom frames could be done using a fastener into the bricks with one at each end and one in the middle, I would use these nodes from Ray
https://www.aliexpress.com/item/BLA...pm=a2g0s.13010208.99999999.259.72a13c001yLknO
Another possible option is the 2" Chromamesh from Boscoyo but I am not sure if these can be joined together or not and I would still need to make some sort of frame and would use these nodes as well https://www.aliexpress.com/item/BLA...pm=a2g0s.13010208.99999999.259.72a13c001yLknO
Below is a picture showing where I want to put this matrix
ma1WujEPzoU9g7rv8
https://photos.app.goo.gl/ma1WujEPzoU9g7rv8
Any input is greatly appreciated
Chris
Trikky72
Hmm I wonder how that would go at rolling up?
Need to be able to get it thru a standard sized door to store under my house
Where on the coast are you located? I am near Wyong
Fing
Muswellbrook
one thing to consider is that you need to keep the spacing even to get a good image etc the Boscoyo mesh works well in this regard. all the strip will tend to sag in the middle, so vertical runs are the best. you will need some kind of solid frame.
Trikky72
Sounds like a plan Troy, you going to be at your work tomorrow by any chance?
Dez
Toowoomba QLD
Hi gang. I have forgotten who here can order the boysico plastic panels for a matrix. Can someone guide me please?
