penguineer
This may be a rather dumb question, and I'm sure I have seen it asked before(and I have searched)......
Which end of a plug set is best for the controller?
I have enough of the Ray Wu moulded plug sets for all of my controllers and lights - the idea is to make everything as plug-and-pray as possible. So before I get into screwing/crimping/soldering a couple of hundred connections I have to decide on which is the best way round.
Female end(with the screw thread) attached to the controllers and the make end(with the screw-collar) on the light strings? Or the other way around?
I have a few screw caps to blank-off unused controller connections/channels so I was thinking the female ends on the controllers as I could blank them off sanely, unused lights just get taken out of the yard........
Plug sets:
http://www.aliexpress.com/item/10-pairs-2-Core-White-Waterproof-pigtail-20cm-long-each-male-and-female-13-5mm-diameter/630889330.html
End-caps:
http://www.aliexpress.com/item/plastic-end-cap-for-the-13-5mm-white-waterproof-pigtail/813548245.html
Any other thoughts?
Cheers!
Plug sets:
End-caps:
Any other thoughts?
Cheers!
