BundyRoy
- Apr 9, 2014
Out of curiosity I got the multimeter out and measured the resistance through my 4 pin 0.75mm2 20cm long pigtails. I was getting readings of around 0.6 ohms. Now even for 14/0.20 cable which is only small the resistance is around 0.043 ohm/m. So on a 5m run (each way) this adds up to a resistance of 10 x 0.043 = 0.43 ohms.
So if my multimeter is even close to right the resistance through a pigtail at each end is 1.2 ohms. I would be better off ignoring the wire resistance and using the pigtail resistance rather than calculating the wire resistance and ignoring the pigtails like I have been so far. The pigtails seem to provide more resistance than the wire.
Is my multimeter way off, am I doing something wrong or is there a lot of resistance in the pigtails. This sort of resistance could lead to significant voltage drop if the strip is using 1.8A per 3m length.
