Pixel mounting strips, fuses and distro/fuse boards on sale until end of June 2020
Use coupon code ENDCOVID in the checkout cart for a 19% discount on top of any other bulk discounts on pixel mounting strip and fuses and power distribution/fuse boards until 1-July-2020. All applicable items will be available for backorder if not in stock.
Stuff that is applicable is
-50m rolls of pixel mounting strip
-my full range of ATO fuses
-my full range of mini fuses
-Power8. 8 way 60A power distribution with inbuilt null buffer
-Hexfuse2. 6 way 3x30A in to 6x15A out fuse board with mini fuseholders and fuse fail leds
-Hexfuse . Same as Hexfuse2 but with ATO rather than mini fuseholders
-Hexfuse kit. Kit of components to build your own hexfuse. Pcb, leds, resistors, fuseholders etc
-Psdist1. Direct mount fuse boards for brick style power supplies
-Psdist2. 12V server power supply fuse board.
-Psdist3. 12V server power supply breakout board
-Psdist6. Direct mount fuse boards for brick style power supplies that have alternate pin configuration to what Psdist1 uses. In general it's "thin" power supplies
-P10fuse. A fuse board designed to mount across the back of P10 and similar panels to provide local fusing with spade fork compatible connectors.
My updated catalogue will be available for download shortly. It has things like the Psdist range of boards, the 4 hole glands, the box with glands fitted and lots more stuff in it.gland.jpgglandbox1-957x1024.jpgHexfuse-300x300.jpgPSdist1.jpgpower8.jpgPSdist2.jpg
http://www.hansonelectronics.com.au
tooms
12v4life
Kalgoorlie
Hi Alan, is your pixel mounting strip similar to what Boscoyo originally came out with? I'm looking to add more strings to my mega-tree but need the same size spacing as what I've already got
Adsy
Sheidow Park SA
Hi Alan just a query on the sever edge connector. Which power supply did you use as a guinea pig?
HP 1200W Power Supply Server HSTNS-PL11
I have intentionally made the resistor which fires up the power supply fairly easily accessible as it appears different power supplies work with different resistors and all the reading I did didn't give me a one sizes fits all. If and when there is problems or adjustments necessary I will detail them on the product pages.
There's actually 2 other boards coming for servers which use a 50 way rather than a 64 way edge connector.
ok thanks. I believe mine has a different pin out so i might have to go with the hexfuse to be sure
If you shoot me details of the power supply I can potentially say yay or nay.
OzAz
Newcastle
Out of interest, on your controller enclosure why only 3 of 4 hole glands? Seeing as most controllers have 16 outputs?
When I originally sourced the boxes they were offering 3 standard single hole glands. I was in the process of chasing 4 hole glands as I thought these were a good option for running pigtails through. If desired it would be possible to fit 5 glands which would do 16 pigtails, ethernet in and out and mains power in and out.
