www.hansonelectronics.com.au
Yes thats the tester i have. I didnt think of lowering the brightness. I have power injected ever 100 pixels but ill try. all pixels where tested before installing. I may try connecting directly to that run and see what happens. starting to do my head in haha.Morning, yes take the 2nd Arch out of the string config, this may cause issue with parts of the Mega Tree that has the same channel number. I had a problem when testing the other day and it turned out to be overlapping channels.
Speaking of testing, on the Test page of the F16 you can run a test mode and switch individual ports on or off. Try running a test with only port 14 active and see what you get. The only other thing I could suggest is to try setting all string outputs down to 30%.
When you said you tested with a pixel tester did you mean one of these?
Pixel tester 2811 | Hanson Electronics
Simple WS2811 pixel tester/controllerwww.hansonelectronics.com.au
I know that feeling, well done on your tenacity to solve it! Only thing left now is to grab a cold one and the camper chair and go out front and watch it while thinking "how can I make this bigger and better next year!?"Woo-hoo. (I did scream that out in my front yard to).
already planning hahahI know that feeling, well done on your tenacity to solve it! Only thing left now is to grab a cold one and the camper chair and go out front and watch it while thinking "how can I make this bigger and better next year!?"
