power cable and heat tube
Helty
Gold Coast
Hey guy,
Where do you guys get your 2 core power injection cable from and your heat tube?
Thanks guys
Heat Shrink:
https://www.ebay.com.au/itm/530-pcs...re-Cable-Insulation-Sleeving-Kit/382462989399
Power Injection cable
https://www.aliexpress.com/store/pr...ml?spm=2114.12010612.8148356.9.5dd08124tDlm1D
Extension Cables: (Try not to go past 8 meter extension cables. You normally degrade signal after 6 meters. This is a complete variable all depends on your setup.)
https://www.aliexpress.com/store/pr...l?spm=2114.12010612.8148356.53.5dd08124tDlm1D
For the other end of my power injection I use figure 8 speaker cable and solder to the pig tail. (Solder -> silicone -> heat shrink)
https://www.ebay.com.au/itm/20m-14a...Audio-with-OFC-Lifetime-Warranty/252800524793
(I normally go to a wholesaler as you can get it cheaper) The other side of the cable goes into a fuse block for power injection with the Power supplies ground connect to the controllers ground.
