Power directly from power supply
Discussion in 'Power Supplies' started by jerrymac, Jul 16, 2016.
  1. jerrymac
    jerrymac Apprentice Elf
    Mar 29, 2011
    72
    0
    Quitman GA
    Any reason not use use power directly from the power supply's and only use the controllers for the data? (two wires from the power supply and one from the controller). Power the controller from a wall wart.
  2. keithsw1111
    keithsw1111 Full Time Elf
    Oct 11, 2012
    385
    59
    Kellyville, NSW
    You have to tie the grounds together but otherwise that is how I run all of mine.
  3. battle79
    battle79 Full Time Elf Generous Elf
    Dec 8, 2012
    400
    3
    Chirnside Park, Victoria, AU
    You will find most people only use the controller for the data signal.
    I run all my light directly from power supplies, with fuses between lights and power supplies obviously.
    As mentioned, make sure you run a ground wire (and only the ground wire) from each supply to the controller ground. If you don't you will get lots of random flashing on your pixels.
    This allows you to utilise the full amount of pixels a particular controller can output, rather than being limited by its power output.
  4. pmflav
    pmflav New Elf
    Jul 5, 2016
    12
    0
    Newcastle
    Does the RJ45 from the controller (F16v2 in my case) provide a ground you can tap into for each powersupply? As this won't/shouldn't be a current loading ground.
  5. i13
    i13 Senior Elf
    Jul 5, 2013
    802
    21
    Just have a common connection between the negative output of each power supply and the negative output from the controller. This can be done through the string of pixels.
    You don't want to have the positive outputs connected together.
  6. battle79
    Dec 8, 2012
    400
    3
    it will, but the easiest way is to use the ground terminal that powers the controller and join that to the rest of your PSU grounds.
