jerrymac
Any reason not use use power directly from the power supply's and only use the controllers for the data? (two wires from the power supply and one from the controller). Power the controller from a wall wart.
Just have a common connection between the negative output of each power supply and the negative output from the controller. This can be done through the string of pixels.pmflav said:Does the RJ45 from the controller (F16v2 in my case) provide a ground you can tap into for each powersupply? As this won't/shouldn't be a current loading ground.
