I think the 0.055 figure should be the current in amps, not the power in watts. That said, you still arrived at the correct figure of 6.6 amps. This is a worst-case-scenario figure. With most pixels drawing less than that, the whole lot might be under 5 amps at 30% brightness. I still prefer not to power through the controller, let alone 400 pixels but this is just a personal preference. There are a couple of reasons:
We're getting to the point where any of the proposed layouts (yours and mine) are likely to work. It is just a matter of figuring out which is the most sensible and practical. For example, if your power supply is positioned close to the controller then your layouts might be easier to build than mine.
- If the data messes up and (worst case scenario) turns on the pixels at 100% brightness white in your scenario 1, this would add up to 0.055 amps × 200 pixels = 11 amps through the controller. The fuse should blow without the controller getting damaged. In your scenario 2, the current in each path will depend on the resistance of each path.
- The ends of a long run of pixels aren't usually a convenient place to connect power. When you inject power part-way along the string, you can power in both directions and therefore power twice as many pixels with the one injection point if your power injection cable is thick enough. Both diagrams attached to this post show powering in both directions.
