aimbrunone
- Jan 19, 2024
My Single Pole Double Throw in On-Off-On. Could this be the problem? Do I need one that is On-On?Hi there! You helped me a few months back with my audio push button box. I'm in need of your help again if you are willing! Things were working for a while then stopped. Couldn't get the push button working, had issues with the relay and can't even remember what else. I did a few modifications to the most current diagram you sent me. I now have two power supplies. 1 36V that only powers the amp. I eliminated the step down and am using a second power supply (12V) to power everything else. I replaced my push button with a new one, replaced the time delay relay with a new one and replaced the DPDT that I use turn the speaker wires on and off. All was good a few weeks ago! Working great! Went out there just now to give it a final test before Thanksgiving and not working properly. I believe the problem is in the Single Pole Double Throw switch that I use to either use the push button or to keep constant sound on. I think at this point, I want to eliminate that switch all together and only use the system as the push button. (The issues the switch is having, is sometimes power does not get to the relay, sometimes it does. Sometimes the relay triggers itself without pushing the button.). The on switch has still consistently worked.
My question is this. Could you please tell me the easiest way to update my diagram so that I can just use the push button? Can I just connect the three wires that come together for the SPDT or do I need to do something else?
Thank you so much!
