David_AVD said:I was actually thinking of wiring a small E1.31 app that can reside in the system tray. It was going to have the scheduling inbuilt.
That was my original plan - to use LSP's "introduction" and "finale" sequences to turn on and off the 240v.. The problem is, there is a bug with LSP where the finale cannot be a sequence file (it allows you to choose a sequence file, but when it goes to play, it gives an error)..David_AVD said:I ended up creating two 10 second sequences (one for power on and one for power off) in LOR to do this instead.
My DMX power boards are set to 2 channel mode so they don't turn back off once the ON sequence finishes and the E1.31 stream for those universes drop to all zeros.
I simply added the ON sequence to the startup section and the OFF sequence to the shutdown section in the show editor.
nato595 said:Any plans to develop more of these relay boards again in the (near) future?
elvatrdude said:David, any plans to produce the quad-relay version in 120V for this season? If so, I'm in for two
