So i'm about to order some pixelstrip from ray...............
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by battle79, Jan 3, 2013.
  1. battle79
    battle79 Full Time Elf Generous Elf
    Dec 8, 2012
    405
    6
    Chirnside Park, Victoria, AU
    Happy New Year everyone,
    I'm keen to get started making some pieces for next year while still motivated. (and not by time getting away)
    So I was wondering is there anything I should be aware of. I know to keep order under $1,000inc, but does that include cost of shipping?
    I understand that the one to get is the silicon tube.
    Main concern is do I need to bother with the 60/mtr??, seems like the few time I've seen it mentioned people seem happy with the 30/mtr.
    Also was 90% sold on the 5V until I noticed that ray has sold 10x more 12V then 5V in the strip? So whats peoples preference? (Don't have suppies for either yet so nothing to loose, only gain)
    60led 60 IC @ 5V http://www.aliexpress.com/store/product/4m-WS2811-LED-digital-strip-60leds-m-with-60pcs-WS2811-built-in-the-5050-smd-rgb/701799_638374848.html
    30led 30 IC @ 5V http://www.aliexpress.com/store/product/5m-WS2811-LED-digital-strip-60leds-m-with-30pcs-WS2811-built-in-the-5050-smd-rgb/701799_653641294.html
    30led 10 IC(easier to program??) @ 12V http://www.aliexpress.com/store/product/5m-led-digital-strip-DC12V-input-WS2811IC-256-scale-10pcs-IC-and-30pcs-5050-SMD-RGB/701799_568458133.html
    Advantages:-
    12V will give me longer runs before I have to inject power right? Hopefully someone has used and can compare to the every ~50 of 5V. Also less channels to program overall.
    Dissadvantages:-
    Less control as pixels are blocks of 3. Leaning toward 12V now as 10 blocks over 1mtr is still heaps.
    Sorry about wall of text, any thoughts welcome. Probably gonna place order in a week or so.
    Cheers,
    Rowan
  2. fasteddy
    Apr 26, 2010
    6,636
    66
    Remember that using individual pixel control compare to 3 pixels has a lot of disadvantages as well, so ive listed a few pros and cons to using 5v individual controlled strip
    Pros
    • finer control
    • more light with 60 LED/M
    Cons
    • Voltage drop concerns
    • Higher current thus meaning larger guage cabling
    • Higer channels to manage and thus a much better computer required to manage and control those extra channels
    • Extra cost due to having to pay for the highest level of channel counts for the software
    • cost of the individual pixel strips is higher
    • More controllers due to more channels used
    If the show is being viewed from the street then reality is that the resolution will not have a big impact and your audience wont really notice the difference. Where i see strip with individual pixel control at 60LED/m then this is best for hi res matrices.
    I always look at what gives me the best bang for my buck and more is not always better and at $32 for a 5 metre strip of 2811, then i still see this hard to beat for value and manageability.
    Others may have differing opinions.
  3. OP
    OP
    battle79
    Dec 8, 2012
    405
    6
    View will be from about 10mtrs away so fairly close. I have ~25 tint tubes I picked up today to mount the strip in so thinking that 30led/mtr will be enough. Gonna just drill two small holes and use wire to make gutter hangers (heatshrink so no rust marks on gutter). Whole house front is 18mtrs across so controller(s) are going 3-4 mtrs either side of the middle. Seperate controller will do the mini trees and candy canes on the lawn. These will be very close to people so will have to make sure build quality is good.
    Think thats more than enough for my first year, but if I'm done by july I may add some more. (Budget allowing, need to run past minister for war & finance)
    Cheers,
  4. OP
    OP
    battle79
    Dec 8, 2012
    405
    6
    At 5V if I inject every 2mtrs, or every tint tube say, that adds up to 60 pixels per section, is that too many in peoples experience?? would be good if I could put injection and connector all in same spot for easy setup and removal.
    Each section of house is either 1.8mtr, 6mtr, or 8mtr, so would work well.
    Cheers,
    Rowan
  5. BradsXmasLights
    BradsXmasLights WiFi Interactive
    Dec 23, 2010
    549
    33
    Brisbane, Australia
    I'd only go 30 LED/m too - and I have people view my display <10m. If your putting LED strip in tint tubes it all blurs anyway - looks 100% fuild :D
    30 LED / M is still bloody bright too - your neighbours across the road may cop it badly if your in a narrow street. 60 LED density will only make this factor worse too. (I actually run mine upside down to reduce colour washing the houses opposite me)
    Go 12V - less voltage drop, and no need to worry about the blocks of 3 LEDs per pixel node, unless you were building a matrix. For most jobs, this stuff is perfect: http://www.aliexpress.com/store/product/5m-led-digital-strip-DC12V-input-WS2811IC-256-scale-10pcs-IC-and-30pcs-5050-SMD-RGB/701799_568458133.html
  6. David_AVD
    Jun 12, 2010
    3,904
    236
    I ended up running my 30 L/M 2811 strip at 25% brightness as it was way too bright at 100%
  7. nutz4lights
    nutz4lights Full Time Elf
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    What is this about keeping orders to under $1000? I haven't seen this mentioned in my reading yet.
    Thanks,
    -Louie
  8. Madko
    Madko Full Time Elf
    Dec 24, 2012
    227
    0
    Castle Hill NSW
    I think anything imported items of the valve of $1000 will incur import taxes.
  9. Benslights
    Benslights Dedicated Elf Global Moderator Generous Elf
    May 2, 2010
    2,452
    159
    Elderslie
    Madko that is correct
  10. fasteddy
    Apr 26, 2010
    6,636
    66
    Its on page 67 (Ordering from China) of the ACL 101 lighting manual.
    Australia is $1000
    For those in the US its $2000
  11. nutz4lights
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    Sorry about that, I stopped reading around the pixel controllers section and hadn't made it back.
    -Louie
