String Flickering / not lighting Issues
I'm not sure how xLights would affect the flickering since you are running the test local.
The color change is very likely a misconfiguration (off by one or two). On the baldrick are they one channel bank or is each panel a separate set of channels?
Assume these are resistor pixels (not regulated)...Your voltage at the start of the string is already marginal. Did you try measuring it with only one panel connected.
6.2v on a 12v pixel is going to be unusable.
If I counted right, there 109 pixels in each panel. You could inject between panels 2 and 3 and between 4 and 5 and get much better voltage consistency. Make sure you tie the controller V- (aka ground) to the power injection V- on the power injection.
