lithgowlights
- May 6, 2010
OK
lithgowlights said:OK I'll try and answer your questions the best I can
I'd like to be able to run your standard Ray Wu style RGB strip, strings or modules. Is the 44CVA the right board for this? I was thinking mini trees or some sort or corro element.
Thats what I plan to use here too. The CV boards as the pixels, modules and strip have built-in resistors to allow them to work on a certain voltage (i.e. 12 or 5V normally)
I see that the boards can be stacked to make say a 48 channel 44CV stack or a 48 channel 44CC stack, is there some sort of order they need to go in for addressing purposes?
Not really. The first element of the stack needs to be a C?A, i.e. a CVA or CCA as that is the Addressable item. It sets the first DMX address, and you can mix and match any of the CC and CV boards below it in whatever order you want depending on your need.
How is the DMX side of things hooked up? Cat cable?
By default there are no connectors, just connection points. Some see this as a disadvantage, but I see it as an advantage. If you want to provide power via the DMX cables then you can. If you have a seperate power supply, you can use that too. Use 3 pin DMX leads for the DMX - well you can add that, or if like me you use RJ45's then you can make a little lead up. It's up to you how you connect things, same as the outputs - you can use a terminal, hard wire (such as in an item), wire up a 2, 3, 4 or 5 pin plug to it and use that to connect to a light, set of lights or 4 individual lights.
Am I right in assuming that I simply feed the required DC supply into the board for whatever is being used, say 5V for the 5V strip?
Yes, I believe so, but there is a small issue with 5V at the moment in that the boards need 7V in to run. MPH is looking at bypassing the internal voltage regulator in the chip so we can feed 5V directly in. For 12V and above this bypass is not needed, and I'm not sure how the final point will be bridged yet as it was a rather late thing I pointed out to him and he had not realised some will want to run 5V gear off it. It will be a very minor update at most
Lastly, and yes I may sound somewhat retarded , but what can I do with the CC board? Well maybe a better way to ask that question is "what is everybody else using the CC board for?"
Initially, nothing here at all. Later on I want to find some stars, simialar to the Tuppet stars, but just the front, and I'll put a few 4 pin RGB (or seperate R G and B) LED's inside to light it up as a double sided star. Perfect for a small topper on a minitree, or to hang in a larger tree as a rather unique home-made item.
The CC's are a small use item here, but eventually I can see myself using more of them, probably in groups here and there around the yard.
kool-lites said:What is the difference between the $3 4 channel "giveback" project and the 44 project?
How do we get them?
Confusedly yours
matt
kool-lites said:$3 to $4 - bit of scope creep or over enthusiastic marketing ( I know what both of those are like). So I need 4 panes to get 40x CCs Correct?
Where do we get them from?
kool-lites said:Where do we get them from?
JonB256 said:I'll be one of those who really don't have a specific NEED for a 44 but WANT a few.
MPH, it would help if your www.dec1.org site did more than give the days until December 1st. Your post just above this one says to go there to register our interest.
JonB
