The most amazing thing I have seen, the Pi Player from Dave Pitts
battle79 said:
in Australia the official distributor is Element14
http://au.element14.com/
Actually costs around $41 + shipping.
Can recommend getting a wifi dongle so that you can connect to if via wifi and use the Ethernet output for e1.31 output.
And depending on how keen you are to get your hands dirty, getting an SD card formatted with OS installed helps you get up and running quicker... I think that's around another $15 or so..
Hi Kane I can't seem to find the card with OS on their website. Can you provide a link?
smeighan said:
can you get amazon stuff from australia?
Every time I try Amazon, I get to the payment page then it says they won't ship to me.
I simply ordered the Pi and the Wi-Pi (wireless adapter) from Element14 over here. Overnight and good price. The SD card I got from one of the electronics wholesalers.
The occasional product can be shipped from Amazon, but most can't be. Which is pretty frustrating!
Amazon were looking at a local warehouse (web link) which I assume would mean that they'd start shipping everything, but not sure what happened with that
Forgot to mention - another source for SD cards here
I have a few SD cards so I mig just try downloading the OS first and see how I go. With the link for Amazon, I can't buy the kit as it won't let me and I can't find the link to he preloaded card only.
David just announced the first release of the pi player.
Thread is on his site. http://falconchristmas.com/forum/index.php?topic=155.0
650mbyte Linux OS + Pi Player image . I already got my image and have the pi player running my 12K channels.
sean
David Pitts said:
You can find the first public Alpha Release here. Alpha 0.0.3
http://sourceforge.net/projects/falconpiplayer/files/FalconPiPlayer_Alpha0.0.3.img.zip/download
We are getting the bug tracking system set up. We may end up using Github's ability to track bugs.
Known things to implement/bugs
1) Repeat/no repeat of playlists in immediate player.
2) First/Last option for playlists.
3) Weekday, weekend and other quick scheduling day options.
4) Better music to sequence data syncing.
5) E131 to Pixelnet/DMX bridge. (Half way done)
6) Video playback, wireless slave operation.
Follow the instructions here to get the image burned to your SD card(4gig minimum). You also need to have a USB memory stick formatted to Fat32 installed in PI to hold media.
http://www.raspberrypi.org/downloads under Raw Images. But use our image instead.
This release is to get you familiar with player and possibly to allow a willing user to create a wiki and/or manual.
This is an Alpha release and will be a bit buggy. This is still a work in progress.
Thanks for your patience.
David and MyKroft
Sean/all:
Does anyone know if the Raspberry PI can be used as a wireless input to a SanDevices E682? This year is my first RGB setup and I would like to avoid routing a 150' or so length of hard line cat5 from inside of my house (from my router) to outside my house, where my E682 will be (I plan to put it within 10' of my arches; I will be running 5V WS2811s). Or perhaps there is some other wireless way of moving SACN data to my E682? Thanks very much in advance!!!
The reason I am using the pi is so I can have the show on the flash drive and rtc on board and run stand alone without any connection to my home network at all. This is for the same reason to cut out the 100 ft cat5 and prevent any lag in the show from the network. I plan to have it in same same box as a switch or bridge with it out in the yard with shorter cat5 to controllers.
I am newbie with RGB controllers, but I "think" there "has to be" a PC running my E682 (?). It has a web-based interface that I am thinking has to be up & running for the controller to be functional. But I am definitely not 100% on that!! Would sure be nice to be able to stick the Raspberry PI into the CG1500 enclosure with the controller instead of tying up a PC!! I will have to look into this.
