Version: v3.5.8 (v3.5 branch) Universe 0
DanielK
First of all, best regards from Germany
I use FPP to control a matrix controller. This has Univers 0 first. Sequences created with xLights work perfectly. If I want to use this as a scheduler / playlist, the first line in the matrix is missing.
Does somebody has any idea?
Thank you and happy Christmas
Daniel
I did not think Universe 0 was a valid universe. The sACN standard only allows universe numbers from 1-63999
ArtNet version 1-3 were with Univers 0, no longer with ArtNet 4. I can't change my controller :)
xLight can do that from 0 to .... depending on how you need it
News from FPP:
Today at 06:14:16 pm #5 OK, I assumed E1.31, but you are using ArtNet and quick research makes indicates universe #0 is valid for ArtNet
so we should allow it in the FPP UI when configuring an ArtNet universe,
but not when configuring an E1.31 universe. I just committed a patch to the master and v3.5 branches of FPP
which will allow this again so you should be able to pull in the latest updates and get the fix.
Thanks to FPP Team
