Hey Geoff,
When setting up a launcher you need to setup a command controller in the controller setup (setup display) and a single element, you need to patch the element to the command controller (mine is RDS/Launcher)
as seen in this link: http://i.imgur.com/SnHQXZi.jpg
You then need to assign the Launcher Effect to the RDS/Launcher Channel in your sequence
Se here: http://i.imgur.com/AdiJyWR.jpg
then you just need to setup what you want the launcher to do, so it starts with my Matrix then opens messaging and after a certain time I close it off, so another one of my matrix's is displayed, but the name does overlay at this stage, I am going to play around with the new version and times to see if I can work out the perfect timing) here is mine:
To Start: http://i.imgur.com/dFxbMHC.jpg
To Stop: http://i.imgur.com/8xPAOQ1.jpg (I just created a bat file to stop it, works perfect)
Hope this has helped you out a little
Brad
Brad
