Wiring 2014 Coles LED Strings into 2811DC30
franky_888
Medowie
I need the assistance of the electrical gurus here please.
I've got a few tubs of coles led strings from the 2014 christmas season, they are 3 wire from the MFC and I want to wire them into a 2811DC30 controller.
Here are the pinouts...
Controller:
String:
Label:
I powered the string up and set the controller to steady on ie all lights on solid. I then disconnected the lights, pulled out the multimeter and measured between the pins on the mfc. Here are my findings:
-ve +ve voltage
Pin0 pin1 +30v
Pin0 pin3 +30v
To me, this means that the led strings are common –ve, and that pin0 is the –ve, leaving pin1 and pin3 to be +ve string 1 and string 2. Is this correct?
If so, as the 2811DC30 is a common +ve controller, the voltages would be around the wrong way to control these lights I’d assume. To address this I believe I would need to wire 1 string between 3 channels so that the voltage runs the right way through the strings Eg +ve to +ve on the DC30, then –ve into channels 1,2 or 3, and control only that channel, meaning I could only control up to 10 of these strings on a DC30 board. Does that make sense?
It seems like a waste but this is only to make do until I can order some custom strings next year hopefully.
If I’ve done something completely wrong here I’m more than happy to be corrected. Thanks in advance.
Maybe try hooking the string to a DC power supply. I don't think you can't really cause any damage with incorrect connections.
franky_888
Medowie
Nice suggestion, I didn't think of that.
After testing it appears my pinouts are correct, but my current flow is not. The strings are common +ve just as the old BIGW strings are (FYI for the future).
