I have recently got me 2 12V-0-12V 300VA toroids and am having some trouble working out how to wire them up.
They have 6 cables (orange, yellow, red, black, 2x blue), I want them to be in series so that I can get 24V @ 12.5A.
I have 3-core electrical cable, I guess the red from the electrical cable connects with the red of toroid 1 and the same for the black. I am guessing, given the big difference in cable thickness, that the 2x blue cables are the output.
If I am correct with these assumptions, that would mean that the orange and yellow of toroid 1 would join with the red and black of toroid 2?
Or is what I have described above parallel? Would the red/black from the electrical cable instead join with both red/black cables on both toroids, and something happens with the orange/yellow cables?
In either scenario, which blue cables on which toroid would I use as the output?
I have a 240V 10A fuse that I plan on using inline on the live wire, would only one be sufficient?
I have read that I should also have a fuse on the output, what size fuse should I be looking for? 24V @ 12A?
The toroids are also wrapped in plastic, does the plastic get removed or is it OK to keep it in the plastic?
Thanks for your assistance, my plan is to get it all wired and then try and find an electrician who would be happy to look it over for safety/correctness so I would like to get as much done as possible before I get them out.
Matt
Matt
