MasterGM
- Aug 29, 2023
Hello!
I'm new to this word of LEDs, and I need some help to see if there is any "ready to use" software to what I'm looking to do!
First of all, a bit of background, I'm using a couple ESP32 with WLED and xLights to drive some leds(around 9k), and.. well it works perfectly, i make the sequencies and run them when needed, but right now I'm looking for a different approach.
See, i want to integrate some sensors to trigger specific (and pre-defined) sequences (that were already made on xLights), all of this on a SBC (like a Raspberry Pi 4)
Now, I'm pretty sure that xLights doesn't have an API at all, so what i would need is something that allows me to run predefined sequences directly from code, like python for example, or any working way that lets me just "run this if that happens".
A pseudo code approach of what I need:
if (sensor_Triggered())
RamdomApiExecuteSequence("\path\of\Sequence")
then, if RamdomApiExecuteSequence is called the Rasp will send the corresponding sequence to the controllers (Multiple ESP32 using WLED) allowing the Image/Sequence to be played!
Thank You so Much!
Thank You so Much!
