Time for a Fosters Alan! Slow your roll.. I do have some 12v nodes that are less than 30ma white 100%. I can power 1,200 of them @30% and an RSP320-12 isnt breaking a sweat. Lets focus on the question from the OP. Mo volts is mo betta but that isn't the subject here. That being said 100% Meanwell here, been there done that with cheap Chinese psu's... No Meanwell failures here with 40+ of themIt's a tad ironic that the use of Meanwell power supplies for their high efficiencies comes up in the same thread as using 12V nodes.
If you actually look at the data sheets you'll see that Meanwell RSP, HRP, LRS series power supplies are typically 75-90% efficient with mid 80's being quite common.
12V WS2811 nodes are by definition only 40% efficient when compared to 5V nodes, 12V nodes use the exact same current to produce the same amount of light as 5V nodes with the balance of the power usage going into heat within the pixel. The fact that you are using 2.4 times the power per pixel means that you also need 2.4 times the power supplies for the same number of pixels.
12V nodes 12V x 0.055A = 0.66W/pixel
5V nodes 5V x 0.055A=0.275W/pixel
12V 400W (33A) power supply = 600 pixels at 100% white
5V 400W (80A) power supply = 1450 pixels at 100% white
<end rant>
Im planning on 5v for all props and 12v only for roof outline.It's a tad ironic that the use of Meanwell power supplies for their high efficiencies comes up in the same thread as using 12V nodes.
<end rant>
Splitting a display across 5v and 12v can cause it's own issues, and I don't just mean plugging...
primarily the confusion created by having different voltage pixels, and the pixels that don't work when powered on, i.e. 12v pixels on 5v power.... I would imagine they wouldn't even light up at that low voltage ?Yes, I understand the 5 volt pixels into 12 volts. Would you explain the other issues a bit more please?
Was planning on using 5v for my mega tree as this reduced the amount of power supplies required.Nothing wrong with mixing voltages for different applications. I used smart receivers to break up voltages as i have props set up as clusters.
I guess different connectors is best practice to eliminate blowouts, or you could order different coloured wiring as a visual reminder. I would also
strongly recommend HP 1200W power supplies. 100A goes a long way.
