Xlights (2026_2) super slow rendering with 'Music Effect'
jz0m64
Adelaide
It's been a couple of years since doing the lights, but trying to get back into it this year.
I run a pi3b, FPP, and DMX2-24 boards and string lights (96 channels this year).
I've finally got my custom model and layout sorted and starting to program some simple sequences like I use to, predominantly using the 'Music Effect' tool/filter. With a quick play on some of the sliders (notes, sensitivity, offset, scale bars etc) I would have a 5 minute song done and saved (auto rendered) in a matter of minutes. However this time round and the current version of Xlights, the rendering is taking an absolute marathon of time. Not sure what has changed?
I couldn't create my custom model the same as last time, but managed to make it them alright in the end. Not sure if this is having an effect or not, otherwise what else it could be? There's no shortage of laptop power on tap and it's certainly not maxing anything out when I have task manager open at the same time.
Any ideas or what I could check? Is it over-rending something invisible or not actually required? For example I just have a 3 strings on the "music effect" for a 4min song and its taken over 5 minutes just to do that. God help me when I have 90+ channels for longer songs.
Ben
2026-11-18 20:32:13.187 [xLights info] SpecialOptions: loaded from exe folder 'C:\Program Files\xLights\special.options'
2026-11-18 20:32:13.187 [xLights info] Start Time: 2026-11-18_20-32-13-755.
2026-11-18 20:32:13.187 [xLights info] Current working directory C:\Program Files\xLights.
2026-11-18 20:32:13.187 [xLights info] ******* OnInit: XLights started.
2026-11-18 20:32:13.188 [xLights info] XLightsSettings: settings file 'C:\Users\send_\AppData\Roaming\xLights\settings.json'
2026-11-18 20:32:13.197 [xLights info] Version: 2026.19
2026-11-18 20:32:13.197 [xLights info] Build Date: Oct 23 2026
2026-11-18 20:32:13.197 [xLights info] WX Version: wxWidgets 3.3.4
2026-11-18 20:32:13.197 [xLights info] Machine configuration:
2026-11-18 20:32:13.197 [xLights info] Total memory: 16384 MB
2026-11-18 20:32:13.197 [xLights info] Free Memory: 9830 MB
2026-11-18 20:32:13.197 [xLights info] Current directory: C:\Program Files\xLights
2026-11-18 20:32:13.197 [xLights info] Machine name: B2_LENOVO
2026-11-18 20:32:13.197 [xLights info] OS: Windows 11 Pro 25H2 (build 26200), 64-bit edition
2026-11-18 20:32:13.197 [xLights info] OS: Windows NT family(XP / Vista / 7 / 8 / 10). 10.0
2026-11-18 20:32:13.197 [xLights info] 64 bit
2026-11-18 20:32:13.197 [xLights info] Little Endian
2026-11-18 20:32:13.197 [xLights info] CPU Arch: x64
2026-11-18 20:32:13.197 [xLights info] CPU: 13th Gen Intel(R) Core(TM) i7-13620H
2026-11-18 20:32:13.198 [xLights info] CPU cores: physical=10 logical=16
2026-11-18 20:32:13.220 [xLights info] GPU: name=NVIDIA GeForce RTX 4060 Laptop GPU | pci=10de:28e0 | memory=7957MB
2026-11-18 20:32:13.220 [xLights info] GPU: name=Intel(R) UHD Graphics | pci=8086:a7a8 | memory=128MB
2026-11-18 20:32:13.220 [xLights info] GPU: name=Microsoft Basic Render Driver | pci=1414:008c | memory=0MB | class=software
2026-11-18 20:32:13.260 [xLights info] Displays: 3
2026-11-18 20:32:13.260 [xLights info] Display 0: 1920x1200 at 0,0 scale 1.00 primary rate=144 rate_max=144
2026-11-18 20:32:13.260 [xLights info] Display 1: 2560x1440 at -1544,-1449 scale 1.00 rate=59 rate_max=180
2026-11-18 20:32:13.260 [xLights info] Display 2: 2560x1440 at 1016,-1440 scale 1.00 rate=59 rate_max=180
2026-11-18 20:32:13.260 [xLights info] Present: allow-tearing supported (variable refresh present path available)
2026-11-18 20:32:13.262 [xLights info] Set VAMP_PATH to 'C:\Users\send_\AppData\Local\xLights\VampPlugins;C:\Program Files\Vamp Plugins'
2026-11-18 20:32:13.262 [xLights info] SpecialOptions: loaded from exe folder 'C:\Program Files\xLights\special.options'
2026-11-18 20:32:13.262 [xLights info] Logger 'xLights' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'render' level set to 'warn'
2026-11-18 20:32:13.262 [xLights info] Logger 'curl' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'opengl' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'job' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Logger 'work' level set to 'info'
2026-11-18 20:32:13.262 [xLights info] Main thread id: 0x4fd8 or 20440
2026-11-18 20:32:13.441 [xLights info] Vulkan compute enabled: NVIDIA GeForce RTX 4060 Laptop GPU (type 2, queue family 2, graphics family 0, size threshold 8192)
2026-11-18 20:32:13.441 [xLights info] Vulkan: device=NVIDIA GeForce RTX 4060 Laptop GPU | type=2
2026-11-18 20:32:13.692 [xLights info] EffectManager: built 56 effects (56 with metadata) in 429.3ms
2026-11-18 20:32:13.969 [xLights info] If xLights crashes after this log message then the root cause is almost always a problem between OpenGL and their video drivers.
We recommend they download the latest drivers from their card provider ... not from their operating system provider.
2026-11-18 20:32:17.035 [xLights info] Directory for *.xvc files not found: .
2026-11-18 20:32:17.035 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: C:\Program Files\xLights\valuecurves\.
2026-11-18 20:32:17.108 [xLights info] Found 16.
2026-11-18 20:32:17.848 [xLights info] SpecialOptions: loaded from exe folder 'C:\Program Files\xLights\special.options'
2026-11-18 20:32:17.848 [xLights info] Logger 'xLights' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'render' level set to 'warn'
2026-11-18 20:32:17.848 [xLights info] Logger 'curl' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'opengl' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'job' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Logger 'work' level set to 'info'
2026-11-18 20:32:17.848 [xLights info] Show directory set to : E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show.
2026-11-18 20:32:17.987 [xLights info] Show id: 2f8d39ab-2f38-4a23-9696-6ee587806ee1
2026-11-18 20:32:18.205 [xLights info] Backup directory 'E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\Backup\2026-11-18-203218_OnStart' created
2026-11-18 20:32:18.246 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:18.246 [xLights info] Found 0.
2026-11-18 20:32:18.246 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\valuecurves\.
2026-11-18 20:32:18.246 [xLights info] ValueCurvesPanel Scanning directory for *.xvc files: C:\Program Files\xLights\valuecurves\.
2026-11-18 20:32:18.246 [xLights info] Found 16.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:18.247 [xLights info] Found 0.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\colorcurves\.
2026-11-18 20:32:18.247 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\palettes\.
2026-11-18 20:32:18.248 [xLights info] ColoursPanel Scanning directory for *.xcc files: C:\Program Files\xLights\colorcurves\.
2026-11-18 20:32:18.281 [xLights info] Found 7.
2026-11-18 20:32:18.281 [xLights info] ColoursPanel Scanning directory for *.xpalette files: C:\Program Files\xLights\palettes\.
2026-11-18 20:32:18.282 [xLights info] Found 10.
2026-11-18 20:32:18.345 [xLights info] Direct2D text rendering enabled
2026-11-18 20:32:18.345 [xLights info] Text rendering backend: Direct2D
2026-11-18 20:32:18.477 [xLights info] XLightsApp OnInit Done.
2026-11-18 20:32:18.552 [xLights info] OpenGL: version=3.3.0 NVIDIA 560.94 | renderer=NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2 | vendor=NVIDIA Corporation
2026-11-18 20:32:18.582 [opengl info] Layout - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:18.582 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.348 [curl info] Adding CURL - URL: https://api.github.com/repos/xLightsSequencer/xLights/releases?per_page=6 Method: GET
2026-11-18 20:32:21.768 [opengl info] ModelPreview - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.768 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.802 [opengl info] Preview - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.802 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.890 [opengl info] WaveForm - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.890 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.912 [opengl info] EffectGrid - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.912 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:21.945 [opengl info] TimeDisplay - glVer: 3.3.0 NVIDIA 560.94 (NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2)(NVIDIA Corporation)
2026-11-18 20:32:21.945 [opengl info] GL backend (compiled): Native
2026-11-18 20:32:22.364 [curl info] CURL Callback - URL: https://api.github.com/repos/xLightsSequencer/xLights/releases?per_page=6 Response Code: 200
2026-11-18 20:32:42.701 [xLights info] Audio file loaded.
2026-11-18 20:32:42.701 [xLights info] Filename: E:\Micro Controllers\Raspberry Pi\Show Folder\Music\4 Not Xmas\Jungle Boogey.mp3
2026-11-18 20:32:42.701 [xLights info] Title: Track 03
2026-11-18 20:32:42.701 [xLights info] Album: Pulp Fiction
2026-11-18 20:32:42.701 [xLights info] Artist: Pulp Fiction
2026-11-18 20:32:42.701 [xLights info] Length: 188917ms
2026-11-18 20:32:42.701 [xLights info] Channels 2, Bits: 4, Rate 44100
2026-11-18 20:32:42.701 [xLights info] DoPrepareFrameData: Start processing audio frame data.
2026-11-18 20:32:42.701 [xLights info] DoPrepareFrameData: Got mutex.
2026-11-18 20:32:42.701 [xLights info] DoPrepareFrameData: Data is loaded.
2026-11-18 20:32:42.701 [xLights info] SetMediaFile: Audio loaded. Audio frame interval 50ms. Our frame interval 50ms
2026-11-18 20:32:42.723 [xLights info] Length 188917ms
2026-11-18 20:32:42.723 [xLights info] Interval 50ms
2026-11-18 20:32:42.723 [xLights info] Samples per frame 2205
2026-11-18 20:32:42.723 [xLights info] Frames 3779
2026-11-18 20:32:42.723 [xLights info] Total samples 8332695
2026-11-18 20:32:43.152 [xLights info] DoPrepareFrameData: Audio frame data processing complete in 451. Frames: 3779
2026-11-18 20:32:46.018 [xLights info] Sequence timing set to 50 ms
2026-11-18 20:32:52.112 [xLights info] New sequence created Type Media Timing 50ms.
2026-11-18 20:32:52.188 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:52.188 [xLights info] Found 0.
2026-11-18 20:32:52.188 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\.
2026-11-18 20:32:52.188 [xLights info] ColoursPanel Scanning directory for *.xcc files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\colorcurves\.
2026-11-18 20:32:52.189 [xLights info] ColoursPanel Scanning directory for *.xpalette files: E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\palettes\.
2026-11-18 20:32:52.189 [xLights info] Found 0.
2026-11-18 20:32:52.189 [xLights info] ColoursPanel Scanning directory for *.xcc files: C:\Program Files\xLights\colorcurves\.
2026-11-18 20:32:52.189 [xLights info] Found 7.
2026-11-18 20:32:52.189 [xLights info] ColoursPanel Scanning directory for *.xpalette files: C:\Program Files\xLights\palettes\.
2026-11-18 20:32:52.190 [xLights info] Found 10.
2026-11-18 20:33:42.394 [xLights info] Aborting rendering ...
2026-11-18 20:33:42.459 [xLights info] Aborting renderers ... Done
2026-11-18 20:34:15.277 [xLights info] Saving XSQ file.
2026-11-18 20:34:15.279 [xLights info] XSQ file done.
2026-11-18 20:34:15.280 [xLights info] Rendering on save.
2026-11-18 20:34:15.280 [xLights info] iseq below effects done.
2026-11-18 20:39:22.365 [xLights info] Render batch complete: 1 jobs over frames 0-3777, 0 suspensions (0ms), 1 row parks, 307085ms, background
2026-11-18 20:39:22.400 [xLights info] Effects done.
2026-11-18 20:39:22.400 [xLights info] iseq above effects done. Render complete.
2026-11-18 20:39:22.401 [xLights info] Saving fseq file.
2026-11-18 20:39:22.413 [xLights info] FSEQFileIO::Write: wrote 3778 frames x 96 channels to E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\Jungle Boogey.fseq
2026-11-18 20:39:22.413 [xLights info] fseq file done.
2026-11-18 20:39:22.413 [xLights info] E:\Micro Controllers\Raspberry Pi\Show Folder\2026 Show\Jungle Boogey.fseq Updated in 307.136 seconds
It's weird... I've been using AI to try fault find and not getting too far. GPU on/off makes little difference. CPU and resources barely used. Reduced the 'custom shape'.... The log as similar stuff to below now...
2026-11-19 21:47:52.980 [xLights error] Render has made no frame progress for 60s.
2026-11-19 21:47:52.980 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 65s, no frame progress for 60s.
2026-11-19 21:47:52.980 [xLights info] All: frame 2 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 137 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 3 of 14004 (frame 3 for 62s, frame 131 for 11s, frame 137 for 8s, frame 139 for 7s, frame 142 for 6s, frame 148 for 4s, frame 154 for 1s, frame 158 for 0s)
2026-11-19 21:48:53.137 [xLights error] Render has made no frame progress for 120s.
2026-11-19 21:48:53.137 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 125s, no frame progress for 120s.
2026-11-19 21:48:53.137 [xLights info] All: frame 2 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 299 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 3 of 14004 (frame 3 for 122s, frame 284 for 9s, frame 289 for 7s, frame 293 for 5s, frame 294 for 5s, frame 299 for 3s, frame 302 for 1s, frame 306 for 0s)
2026-11-19 21:49:53.294 [xLights error] Render has made no frame progress for 180s.
2026-11-19 21:49:53.294 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 185s, no frame progress for 180s.
2026-11-19 21:49:53.294 [xLights info] All: frame 2 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 454 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 3 of 14004 (frame 3 for 182s, frame 328 for 51s, frame 422 for 13s, frame 425 for 12s, frame 427 for 11s, frame 435 for 7s, frame 452 for 1s, frame 454 for 0s)
2026-11-19 21:57:06.418 [xLights error] Render has made no frame progress for 60s.
2026-11-19 21:57:06.418 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 618s, no frame progress for 60s.
2026-11-19 21:57:06.418 [xLights info] All: frame 1346 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 1492 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 1347 of 14004 (frame 1347 for 68s, frame 1490 for 9s, frame 1492 for 8s, frame 1495 for 7s, frame 1505 for 3s, frame 1507 for 2s, frame 1510 for 1s, frame 1513 for 0s)
2026-11-19 22:02:31.262 [xLights error] Render has made no frame progress for 60s.
2026-11-19 22:02:31.262 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 943s, no frame progress for 60s.
2026-11-19 22:02:31.262 [xLights info] All: frame 2136 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 2309 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 2137 of 14004 (frame 2137 for 70s, frame 2285 for 9s, frame 2287 for 9s, frame 2289 for 8s, frame 2302 for 3s, frame 2304 for 2s, frame 2307 for 1s, frame 2309 for 0s)
2026-11-19 22:03:31.420 [xLights error] Render has made no frame progress for 120s.
2026-11-19 22:03:31.420 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 1003s, no frame progress for 120s.
2026-11-19 22:03:31.420 [xLights info] All: frame 2136 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 2455 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 2137 of 14004 (frame 2137 for 130s, frame 2413 for 17s, frame 2423 for 13s, frame 2440 for 6s, frame 2442 for 5s, frame 2450 for 2s, frame 2453 for 1s, frame 2455 for 0s)
2026-11-19 22:04:31.574 [xLights error] Render has made no frame progress for 180s.
2026-11-19 22:04:31.574 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 1063s, no frame progress for 180s.
2026-11-19 22:04:31.574 [xLights info] All: frame 2136 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 2590 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 2137 of 14004 (frame 2137 for 190s, frame 2589 for 6s, frame 2590 for 5s, frame 2594 for 4s, frame 2595 for 3s, frame 2598 for 2s, frame 2600 for 1s, frame 2604 for 0s)
2026-11-19 22:05:31.734 [xLights error] Render has made no frame progress for 240s.
2026-11-19 22:05:31.734 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 1123s, no frame progress for 240s.
2026-11-19 22:05:31.734 [xLights info] All: frame 2136 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 2744 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 2137 of 14004 (frame 2137 for 251s, frame 2638 for 46s, frame 2733 for 7s, frame 2741 for 4s, frame 2744 for 3s, frame 2745 for 2s, frame 2749 for 1s, frame 2751 for 0s)
2026-11-19 22:06:31.889 [xLights error] Render has made no frame progress for 300s.
2026-11-19 22:06:31.889 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 1184s, no frame progress for 300s.
2026-11-19 22:06:31.889 [xLights info] All: frame 2136 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 2899 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 2137 of 14004 (frame 2137 for 311s, frame 2638 for 106s, frame 2745 for 62s, frame 2882 for 7s, frame 2894 for 2s, frame 2895 for 1s, frame 2898 for 0s, frame 2899 for 0s)
2026-11-19 22:16:57.513 [xLights error] Render has made no frame progress for 60s.
2026-11-19 22:16:57.513 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 1809s, no frame progress for 60s.
2026-11-19 22:16:57.513 [xLights info] All: frame 4253 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 4427 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 4254 of 14004 (frame 4254 for 71s, frame 4403 for 10s, frame 4406 for 8s, frame 4411 for 6s, frame 4419 for 3s, frame 4421 for 2s, frame 4423 for 1s, frame 4427 for 0s)
2026-11-19 22:28:12.354 [xLights error] Render has made no frame progress for 60s.
2026-11-19 22:28:12.354 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 2484s, no frame progress for 60s.
2026-11-19 22:28:12.354 [xLights info] All: frame 5907 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 6072 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 5908 of 14004 (frame 5908 for 67s, frame 6033 for 15s, frame 6049 for 9s, frame 6050 for 9s, frame 6051 for 8s, frame 6066 for 2s, frame 6067 for 2s, frame 6072 for 0s)
2026-11-19 22:32:46.887 [xLights error] Render has made no frame progress for 60s.
2026-11-19 22:32:46.887 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 2759s, no frame progress for 60s.
2026-11-19 22:32:46.887 [xLights info] All: frame 6570 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 6740 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 6571 of 14004 (frame 6571 for 70s, frame 6726 for 6s, frame 6729 for 5s, frame 6734 for 2s, frame 6735 for 2s, frame 6737 for 1s, frame 6738 for 0s, frame 6740 for 0s)
2026-11-19 22:33:47.066 [xLights error] Render has made no frame progress for 120s.
2026-11-19 22:33:47.066 [xLights info] Stalled: batch 1/1, 1 of 1 jobs outstanding, frames 0-14015, running for 2819s, no frame progress for 120s.
2026-11-19 22:33:47.066 [xLights info] All: frame 6570 of 0-14015, holding a render thread, phase frames, last rendering effect at frame 6885 layer 0 submodel -1 strand -1 node -1, frame-parallel window [0,14003] finished 6571 of 14004 (frame 6571 for 130s, frame 6860 for 10s, frame 6861 for 10s, frame 6863 for 9s, frame 6864 for 9s, frame 6876 for 4s, frame 6880 for 2s, frame 6885 for 0s)
