Bryan H Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 #1 Anyone know what this error means. I can't access this one sequence on the main file, back up and the back up back up USB drive... The sequence still plays on xscheduler, but I can't get in to update the sequence in xlights. Attachments xlights capture.JPG 96.4 KB · Views: 16
David_AVD Grandpa Elf Community project designer Joined Jun 12, 2010 Messages 4,717 Location Victoria Point (Brisbane) Dec 17, 2017 #2 It would be that the xml file that the sequencer uses is corrupt, but the fseq file (that the scheduler uses) is ok. That's my understanding on how it works, but I could be wrong.
Bryan H Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #3 Thanks David, any known fixes....
David_AVD Grandpa Elf Community project designer Joined Jun 12, 2010 Messages 4,717 Location Victoria Point (Brisbane) Dec 17, 2017 #4 After having a look at the xml file, lines 1390 to 1529 are corrupt. Copy the file with the .xbkp extension to a new name, then change the extension to .xml and you should be able to open it in xlights.
Bryan H Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #5 done as you have suggested and it works... Thankyou David... I thought I would have to rewrite the sequence again...
David_AVD Grandpa Elf Community project designer Joined Jun 12, 2010 Messages 4,717 Location Victoria Point (Brisbane) Dec 17, 2017 #6 Whooo!!! Blinky-on my friend!
keithsw1111 Senior elf Joined Oct 11, 2012 Messages 968 Location Kellyville, NSW Dec 17, 2017 #7 What version were you using. I would like to have seen the file with the error.
Bryan H Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #8 Still have it Keith, I would have saved it under .39 and opened it in .42. Can send it to you.
Bryan H Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #9 Email with files corrupted file sent with the backup that works..
