Sequoia Drive Lights Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 #1 Anyone know what this error means. I can't access this one sequence on the main file, back up and the back up back up USB drive... The sequence still plays on xscheduler, but I can't get in to update the sequence in xlights. Attachments xlights capture.JPG 96.4 KB · Views: 16
David_AVD Grandpa Elf Community project designer Joined Jun 12, 2010 Messages 4,640 Location Victoria Point (Brisbane) Dec 17, 2017 #2 It would be that the xml file that the sequencer uses is corrupt, but the fseq file (that the scheduler uses) is ok. That's my understanding on how it works, but I could be wrong.
Sequoia Drive Lights Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #3 Thanks David, any known fixes....
David_AVD Grandpa Elf Community project designer Joined Jun 12, 2010 Messages 4,640 Location Victoria Point (Brisbane) Dec 17, 2017 #4 After having a look at the xml file, lines 1390 to 1529 are corrupt. Copy the file with the .xbkp extension to a new name, then change the extension to .xml and you should be able to open it in xlights.
Sequoia Drive Lights Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #5 done as you have suggested and it works... Thankyou David... I thought I would have to rewrite the sequence again...
David_AVD Grandpa Elf Community project designer Joined Jun 12, 2010 Messages 4,640 Location Victoria Point (Brisbane) Dec 17, 2017 #6 Whooo!!! Blinky-on my friend!
keithsw1111 Senior elf Joined Oct 11, 2012 Messages 980 Location Kellyville, NSW Dec 17, 2017 #7 What version were you using. I would like to have seen the file with the error.
Sequoia Drive Lights Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #8 Still have it Keith, I would have saved it under .39 and opened it in .42. Can send it to you.
Sequoia Drive Lights Bryan Joined Feb 15, 2017 Messages 181 Location Tamworth Dec 17, 2017 Thread starter #9 Email with files corrupted file sent with the backup that works..
