orchidman33
- Jan 14, 2019
I'm having an issue! I have sequence that I want to test on my Falcon F16v3 controled by a Pi 3B + . I have setup 12 universe all with 510 channels( used multi cast at this time), set the chanel numbers and ports in the layout, used 'check sequence' - on issues here.
I have then gone to the Pi, set the channel inputs (18 inputs, E1.31/multi cast, 510 channels).Channel otputs have also been setup,18 universe, 510 channels each,multicast,
the Falcon has been setup as follows - 12 inputs with 510 channels,all E1.31and 16 string ports.
I am able to ping the Falcon and upload sequence and audio/video with not probem.The test feature on the Falcon turns the lights on as it should and so does the test on the FPP. But when I come back to xlights the test function and even playing the sequence with the FPP in bridge mode does not work.I am able to play the sequence with the FPP in standalone mode.
Where have I gone wrong or what have I not done - HELP
