Release 2020.52 Released
keithsw1111
Kellyville, NSW
2020.52 December 5 2020
— enh (scott) Added click-and-drag & double-click select to SubModel Preview
— enh (scott) Add sort of nodes to rows in submodel dialog
— enh (keith) Added experimental KiNet support
— enh (keith) Add F4/F5 and F7/F8 to move nodes forward/backward between layers in custom model dialog
— enh (keith) Add option to disable sending of data to controllers that are not responding to ping to reduce ARP failure delays
— enh (keith) Add support for !controller:startChannel format in xSchedule for defining matrix start channels
— enh (keith) Add a filter to the model group panel to quickly find models to add into a group
— enh (keith) On batch render dialog show the number of sequences selected
— enh (keith) Add a right click option on custom model data grid to convert a pixel model to a single channel model
— enh (keith) Increase the x axis granularity for custom value curves
— enh (keith) Add support for SVG colour palettes
— enh (keith) Further improve visulaliser bank error messages
— enh (dkulp) Try to use the best GPU for shaders and support eGPUs on OSX
— bug (keith) Fix backup fails when recovering an rgbeffects xbkp file
— bug (keith) Fix serial port start channel is incorrect in visualiser where first model does not start on channel 1
— bug (keith) Fix custom value curve editor does not allow editing of all points
— bug (keith) Fix an LMS import crash
— bug (keith) Fix opening of SCSS colour palettes
— bug (keith) Fix freeze frame is not large enough and can limit length of effects
— bug (dkulp) Fix some rendering crashes if you manipulate models
— bug (dkulp) Fix FPP dicovery fails on all but the first attempt
— bug (dkulp) Fix model in group can move relative to the rest of the group in the model preview due to double scaling
— bug (pete) Fix random number generator is not as random as it should be
