ABS enclosure power connection
goopy
Australia
What is considered best practice for providing power to the junction / project box? I am having trouble finding a waterproof (IP44?) socket that would be suitable. Do others just run a power lead out of the box?
Cheers,
Chris
Grandpa Elf
A lot of people use cable glands for DC cabling. I've done the same for an incoming mains cable, but that was a fixed tail.
If this is for mains, make sure you use something that is rated for 240V operation and 10A.
Caravan inlets may suit, but they tend to be a bit on the bulky side.
Elecgreg
The Rock
The caravan inlet style only come in 15 amp version there is an industrial 56 series if memory serves but the are both pricey $50 mark
TANSA
Sparky with Blinky Lights ;-)
Bentley Park
bpratt
Jimboomba, Queensland
As it has been said, use a licenced electrician for all of your mains powered stuff.
That said, people often use an extension cord with the tail cut off and inserted in to the controller box through a gland, and then to your meanwell psu's.
goopy
Australia
Thanks all, I think I will go with the inlet plug and then get it checked by an A Grade before connecting to mains / powerimg on.
